All fuses ok?
All sensors should withstand disconnecting the battery.
Looking at the crank sensor is not a bad idea. If it failed the battery disco is coincidental.
Validate the distributor, rotor and cap are ok.
Verify coil voltage to the coil.
CPS could be bad as well.
Only use OEM sensors.
Regards,
JPNinPA
Sent using TapTalk
