The plugs for 1 & 2 looked fine as well as the wires. The plugs for 3 & 4 looked fine but there was corrosion inside the boots for both plugs
Again try disconnecting the O2. Then the air temp sensor.
By unplugging the O2 sensor, this causes the EUC to go into OPEN2 loop according to the scanner. It seems like the issue is related to the primary OPEN loop mode and whatever sensors are read during that time. The secondary open loop (OPEN2) appears to bypass the initial sensors from primary open loop and operate directly from the ECU. From the research and web crawling, here's what I found from Warm-Up mode and the sensors involved
ENGINE WARM-UP MODE
This is an Open Loop mode. During engine warmup, the powertrain control module (PCM) receives
inputs from:
- Battery voltage -
Brand new battery installed on Friday Nov 21
- Crankshaft position sensor -
Replaced on Sept 18
- Engine coolant temperature sensor -
Replaced on Nov 20
- Intake manifold air temperature sensor -
Replaced on Nov 20
- Manifold absolute pressure (MAP) sensor -
Replaced Sept 18
- Throttle position sensor (TPS) -
Replaced Sept 18
- Camshaft position sensor signal (in the distributor)
- Park/neutral switch (gear indicator signal—auto. trans. only) -
N/A – Manual Trans
- Air conditioning select signal (if equipped) -
N/A – No A/C
- Air conditioning request signal (if equipped) -
N/A – No A/C
