Thats a lot of lift for 33" tires. if your going to SOA (about 5.5" lift) at a minimum I would run a 35" tire, personally I would be more in teh 38-40" tire range with a properly set up SOA.
If you have no desire to go bigger than 33" tires, and the specs you list, the gears and lockers..I would get a 8.8 or d44 rear, D35's, even with stock tires, are not a happy axle when locked. for the front, I would swap out the shafts and Pass seal for TJ shafts. I would run about 2-2.5" of lift and a 1" body lift with a flat belly skid and SYE. This will give you about the same diff clearence as a D60 and 37" tires and the belly clearence of a 5" lift.
