Hi everyone,
I recently bought a resotred CJ5, physicaly beautiful, but upon inspection of the engine bay, I knew few things were not properly done.
I am not sure what diagram would fit my setup so I am looking for some help. Also what parts could fit for the CTO Switch and PCV Valve?
This is a 1979 i6 258 block, everything seems stock on it. Not sure what more info would be needed.
Thank you in advance for any help.
The brake booster cable seems fine, not sure what the black tubing hoop is for.
PCV valve was shot and was wired to the clean air input, the filter is full of oil oviously and must have pressured the gasket and created leaks?
The distributor is not connected to anyhting
EGR Valve and Carburator directly connected to the front EGR CTO Switch. Shouldnt there be a THermal vacuum switch?
the orange hose from the air filter entry goes to the carb, going all the way to the bottom of the engine and around the steering column
The rear CTO Switch is dead and not connected to anything. I believe this is the issue with the rest of the build
Hose coming from the bottom of the carb and was just hanging at the back of the engine.
Top view of the carb
