AKASHAJEEP
RE: homeschooling
I just went out today and took some measurements, and am ready to buy some shims and a extension of the yoke to get rid of MY vibes. found out they are being cause by the stock yoke being too short and the driveshaft about to fall off the splines!! (yes she is down for the moment)
I took some measurements while under there though to decide on what degree shims to get.
the top of the drive shaft is at 17* while the bottom of the shaft is at 13*. do I just simply subtract the two and get the 4* shims? or is there something else involved? also the top of the rear housing is at 10*
what do you suggest for the degree of shims to be used?
I also have 5.5" of lift in front and 6" in the rear. THX guyz!!
