how to hide that sub?
1063658
hey i made a custom center console that bolts right to the body and has 12 in sub under it. Then i bolted down the amp under the driver seat. Also i put two more in a box behind the back seat. If you have a tj or yj you can do what i did ..i put a piece of steel across the fender well where the roll cage bolts down, then put one under the back seet right behind the box. If you do that you can lock back door nobody can lift it up of pull it through the front. If you want some pics let me know ill try to get them to you ...let me know how it goes! [addsig]
1063722
Hey, I got a 10" JL audio in a box that was built by them. It fits perfectly in the add-a -trunk feature that Quadratec sells. Sounds great with the top on, but when you remove it you lose all the bass that makes up for the sound bars weakness. Also recomend getting bass blockers for your other speakers unless you have a good X-over. I've seen the steel thing done like WranglrWhat94 has. That might work better so you don't have the add-a trunk blocking the sound with its metal like cage.
Good luck!![addsig]
