graewulf
something is binding up?
Well, the lift finally arrived last week for my friends XJ. So, yesterday was the big day, his XJ was goign to finally grow up. He got the RE budget boost. After getting it installed, i would say that it is definitely worth it. We started out by doing the front end. It went pretty smooth.. Just disconnected the factory shocks, jacked it up nice & high, took the tires off. The springs came out without much trouble. Putting them back in with the 2" spacers was another matter. Since we didn't have a spring compressor, we used pry bars and managed to get it back in. For the second one we decided to turn the Hi-lift into a spring compressor and use zip ties to hold it compressed. It worked...
The Jackmate came in handy.
Before Pic
After Pic
Then the fun began, we removed the rear leaf packs, inserted the Add-a-leaf (recommend a grinder to remove the bands if necessary), and got them ready to reinstall.
Then came the removal of the rear shocks. Of course something had to go wrong, this was it.. 3 of the 4 upper shock bolts snapped off when we tried to remove them, so 3 hours and 2 taps later (EZ outs couldn't budge them, snapped one tap off in the hole), we were ready to reinstall the rear springs and shocks. All said & done, almost 10 hours later (should have been done in about 5) we had a lifted XJ...
Before
Front Done
All Done
Now for the fun stuff...
Before
After
And now for some stats:
Measured - Before - After
Tire to Flare Front (articulated) - 12" - 15"
Tire to Flare Rear (articulated) - 7" - 10"
Front shocks (full drop no tires) - 22" - 23.75"
Rear shocks (full drop no tires) - 19.5" - 22"
RTI score (calculated based on measurements, only approximate) - 545 - 717
He gained at least 6" of articulation when off camber, and maybe more - the front brake lines need to be relocated lower, since they stretch to the max (probably are limiting the front travel at the moment). This lift is worth it for the $200 invested. We can't wait t get it offroad and see what i will do. I'll be ordering one for my ZJ hopefully by summer.
Before Pic
After Pic
Before
Front Done
All Done
Before
After
