There are many drawbacks to doing a spring over axle lift, or SOA, namely axle wrap which can be disastrous if you don't do something about it. A SOA lift gives you about 5", you will need longer shocks, brake lines, custom rear driveshaft, drop pitman arm, etc. and will be expensive and a lot of work. If you don't want to spend a lot of $, then just buy some 2.5" lift springs--with a 2.5" lift, you don't necessarily have to change your shocks, brake lines, or driveshaft (although it wouldn't be a bad idea), and it won't give you axle wrap.
