Hello,
I am new member from NM.
I have bought a wonderful 99 Jeep Wrangler 5 months ago with low mileage, putting into the garage for safe keeping out of the sun. To say the least I have not put that many miles on the Jeep before I rolled it on our first Snow storm of the season. I did not get hurt and am very thankful for the roll cage. I am now repairing it and need some help. I am in the process of realigning the rear axel and install new support members. I have put new coil springs and upper and lower supports on both sides . Re-welded the track bar where it crack the weld. I left the old track bar in temp to see where the axel set in reference to the frame. I have figured from the frame I am about 3/8" off being equal on each side however the old track bar is 2" from its mount hole. I have order a new track bar but I can't see where the old one can be out 2 ". Is there anything I should be looking at? The Jeep does not have a lift lit on it. I know I will need to have it check out by a mechanic shop for proper alignment and safety before putting it back on the road.
Thank you
Thank you
