secondary elec fan
mrhowiepc
elec fan not turning on. I tested it by wiring up to battary and it work's. But when temp goes up it don't turn on. I looked for fuses but can't find one ?? What else do i need to check or test ??? :confused: :?:
Welcome to the Z. What year jeep?
Could be a bad fan relay, you can test by swapping in a different relay or using a jumper wire to activate the fan manually.
turn on the AC if you have it, this turns the fan on instantly if the fan runs its probably your temp. sensor located on the thermostat housing if not its most likely the fuse or the fan relay located in the fuse box under the hood behind the battery there's a relay and fuse directory under the cover
