Scotts cj7
What should the timing be set at on my 1985 258 six ?
Forgot to mention that the vacuum line should be removed from vacuum advance and plugged . Also , any electric motors that may be on the carburetor , I.e , a/c idle boost , anti-diesel solenoid , idle speed control , etc. must be disconnected temporarily until timing is set. I could not properly identify which ignition system your engine has so I do not know which distributor it has but if there is a computer feedback wiring harness for advance/retard control , it will have to be temporarily disconnected as well . It is always best to disconnect any electrical with ignition off and reconnected ignition off as well. The purpose of disconnecting vacuum and electrical is so that base timing can be set without engine vacuum cannot disturb idle and throw off setting and computer feedback wiring disconnected so the ECM cannot correct settings your trying to set. One more item ; disconnect and plug EGR vacuum and emissions control such as evaporative emissions canister vacuum .The chilton manual for this model year has it at 9 degrees BTDC and 600 rpm idle speed for auto trans.
