What would you like to learn?!!!!!!!
Voltage, amperage, Hz!?!?!? I thinks it's time for me to meditate.........................................
Ohm..............ohm..................ohm.........................
Nick, I'm not sure where you got your info on telephone lines, but ...
A telephone line is 48V DC, but when it rings, it is 48V AC, not 90-120V - which would fry a ringer set. You are correct that it is normally not 60 hz, but the actual frequency varies between different types of switching and central office equipment.
A solid short circuit would quickly fry an OE port in a central office. It is all electronic these days and the line will shut down automatically within a few seconds. The power supply for plain old telephone service is still a large bank of big 48V batteries in vaults underneath the C.O.'s.
A telephone line with a DSL still runs on 48V dc. A T1 or any other high-capacitance circuit can run at voltages substantially higher then 60 volts, in many cases more than twice that amount and can be quite deadly.
The threshold for high/low voltage is 60 volts - at least as the federal government sees it from a safety standpoint. That is the minimum voltage that can throw a heart into fibrillation (as I mentioned above). That is why OSHA requires CPR/first aid for those employees. I am sure that in any given field that deals with electricity, their view of what high and low voltage varies but it is 60V as the feds see it.
I have on many occasions worked in the wet weather and got into ringing voltage . It hurts and will leave burn marks on the skin. It's not lethal, but as I stated above it will give you a little respect for low voltages and it'll definately get your attention.
Trust me I am sure about this stuff. It is what I do. I didn't want to get into an electrical pissing match with ya, I just wanted to point out that low voltages are often underestimated. I hate to see it talked about so casually, as these welders have the power to melt metal.
On a side note, if anyone has ever seen the result of a set of auto jumper cables hooked up backwards it can give you an idea what merely 12V is capable of when there is alot of current present. Do you not have a warning label in your 12V electric vehicle?????
RE: sm420
Hi,
These are quotes from multiple web sites I found after doing a yahoo search:
According to AT&T, the ringing signal is an 88v 20Hz A.C. signal superimposed on 48v nominal D.C. supervisory voltage. However, the actual ringing signal used can and does vary greatly from one location to another. The frequency of the AC signal is normally between 15 and 70Hz.
The Central Office sends the following: a 90 to 120 VAC ringing voltage, Frequency of 20 Hz, Cadence for North America is 2 sec On/ 4 sec Off
The telephone company sends a ringing signal which is an AC waveform. Although the common frequency used in the United States is 20 HZ, it can be any frequency between 15 and 68 Hz. Most of the world uses telephone frequencies between 20 and 40 Hz. The voltage at the subscribers end depends upon loop length and number of ringers attached to the telephone line; it could be between 40 and 150 Volts.
The connected switch will superimpose a Ring Voltage of approximately 90 VAC over the DC voltage. A capacitor in the phone allows the passage of AC current, but blocks DC current. Upon detection of the Ring Voltage, the phone will provide an audible signal that alerts the user of an incoming call. Ring Voltage provided is between 90 and 140 Volts, Alternating Current and has a frequency in the range of 15.3 to 68 Hz. Typically, a frequency of 20 Hz is implemented.
According to these sources, ring voltage *could* be as low as 40 volts, but I still believe it to be much higher, as the other sources indicate. Not only do I believe this because have built my own ringer circuit before, in which I had to use above 60 volts, but I also bought an actual telco ring generator which I found surplus. It has clearly marked outputs which say "Output: 90-120 VAC, 30Hz" I have used this ring generator on many phones, and there have been no problems.
Then the current is limited...
Yes, it does vary. I believe the auto industry considers anything above 50 volts as high-voltage.
Are you sure it was only 48 volts? Burn marks and such would make me think it was a higher voltage that got you...
No pissing here. However, I'm going to do a bit more research on this now, as you've made me curious....
Are you referring to car batteries potentially exploding due to seeing reverse current? If so, that kind of result could occur on a battery of any voltage. Batteries don't much like it.
-Nick :!:
My dad just told me that very bad, and expensive things would happen, so despite my nightmarish curiosity, I have never done, nor seen such things...
window zipper problem
XJNick said:
Hi,
Well Nick AT&T doesn't own any telephone networks. They are a long distance and wireless company among other things. their stuff is all on fiber optics.
the voltages and references I made are (at present) true for the Mid Atlantic area. As I said I work with it every day. The info may be quite old as may the ring generator you purchased. Another possibility is some ring generators that were used in large buildings were not of the same spec as the network. There were special telephone sets used with them though.
Take a multimeter across your phone line and call it Nick. It will read around 50VAC. Give or take 5V or so. If your feeling frisky, wet your fingers and grab ahold, but don't say I didn't warn ya :lol:
not disputing that, just giving info
Absolutely sure. This usually happens when lines are not receiving calls and I am testing ringing voltage. I have been doing this for years and never have I seen a properly working circuit carry over 55 volts AC while ringing.
No, I was referring to melted terminals and burned up jumper leads not battery explosions. A 1.5v triple A battery can explode, but it won't melt metal or burn fingers.
If you are in Texas, you are probably in old GTE territory (now Verizon). I am not sure if the network is the same there as the former Bell Atlantic area (now also Verizon) that I work in, but I would assume they are very similar if not the same.
You do understand where I was going when I asked about you having a warning label on your electric Jeep, right? All I'm saying is low voltage can be hazardous. It is not always, and rarely the case, but it can be.
One other thing, the info you got from ATT is referring to an old electric-mechanical switch type system. There were several different types of switching equipment and hardly any of them are used today. Most lines work on technology like Starspan, Lightspan 2000, SLIC-96, and newer electronic office equipment (a 5E switch for example) that uses inter-office multiplexers instead of copper trunk cables to communicate between them.
RE: Re: Here are some progress pics
Hi,
The ring generator I bought doesn't appear to be very old at all. I don't know when it was made, though. I'm not disputing that you work with telco stuff everyday. I believe you. However, I've found that the ring signal here is different from what you posted (see below)
I did measure the ring voltage and frequency with a good multimeter just a few minutes ago. I saw between 88 and 92 volts AC at 24.5 Hz coming across the line during ringing. This was of course with the multimeter on the AC scale. I checked the line with the meter on DC (when all phones were on hook), and saw 51.4 volts DC. So you are correct, the normal voltage is about a 48 volt system. Note, that the 51.4 volt DC signal was STILL PRESENT on the line while the ring signal was on the line. This makes perfect sense if the AC voltage is superimposed over the DC voltage as the internet sources I read stated. So yes, there is about a 48 volt DC voltage on the line during ringing. but, there is also around a 90 volt AC signal present, and THAT is the one that will certainly shock you.
Oh, and I don't need to be electrocuted to sense the voltage. That is what multimeters are for. :P And yes, I certainly believe you when you say that it hurts. :D
I'm not here to try to prove you wrong. I believe you if you say that a 50 volt AC ring signal is what you see on phone lines in your area. I'm just pointing out that I see 90 volts AC during a ring signal on my phone line, and that also happens to be what my ring generator produces. I too am sure that TelCo signals vary by region. The above info is simply based on what I see here (in central Texas).
Yes, and I do have warning labels. Though, I wouldn't classify my Jeep as being low voltage. It is 160 volts DC... :mrgreen:
However, you bring up a good point. Low voltage can be dangerous. High voltage can be dangerous. Electricity in general can be dangerous. It is all about using the right tools, using common sense, and not working with power systems that you are not familiar/ comfortable with. This is why I find it annoying when people say that electric vehicles are more dangerous than gas-powered vehicles due to the higher voltage....
-Nick :!:
RE: Selling the Jeep (ouch)
Just for kicks I just tested mine. 46V AC ringing voltage (I didn't bother testing frequency). I was already aware that the DC voltage remains on the line while it rings, and it is one of the only examples of the two types of voltage being run on the same circuit of anything I have ever dealt with. I never would have thought that possible before working for the phone company.
I guess the telco equipment varies more than I thought. I figured yours would have been closer to 50V. I wonder why that system uses a higher voltage, as I don't start to troubleshoot a line unless it drops below 40VAC.
Good to know though, and it'll have me picking the brain of a couple of the old-timers at my work location :)
As for your Jeep being 160V, I'm going to quit while I'm behind :) but I'm glad we agree on the safety issue. I felt the need to state it when I got a mental image of some welder-to-be checking to see if he could really shock himself harmlessly :lol:
is there anywhere like this on the east coast.
I was welding something ( dont remember what) the garage floor was damp.
Hot outside maybe 80-90 and like 60 in the garage. So the floor starts to condensate.
Anyway, I was using a Lincoln Arc (set about 120 amps) and was Shocked across my back ( I was on my back under the car i think.) I remember it feeling like needles.
RE: My Jeep
G-G-G-G-g-g-g-g-r-r-r-r-o-o-o-o-o-a-a-a-a-n-n-n-n-!-!-!
HAHAHAHA!!!!
Okay…while we wait for Nick and Twisted to sort out the scintillating details of their rather shocking discussion…:wink:
(Twisted and Nick are both correct. Telephone signaling techniques have evolved over decades. It depends on the system in question and where and how voltages and currents were measured in that system.)
POP-QUIZ
Can any of our techies name this bird?
(The answer is given below, but you will have to turn your monitor upside-down to read it.)
(You should hum the "Jeopardy" tune while pondering your answer.)
Regards,
Gadget
PS: Yes, I do know that I have way too much time on my hands.
:roll: :roll: :roll: You just brought a smile to my face, not easy to do since I just got home from unloading food-truck in the rainy snow that we had this morning. Thanks :)
Ok, I'm all out laughing right now, roomies must think I'm nuts...
Hi,
Maybe Sully or Bounty Hunter could split all of our posts regarding Telephone lines into a new thread???
I really didn't mean to clutter this thread with facinating, yet irrelevant information... :mrgreen:
-Nick :!:
-Nick :!:
I agree, it got waaay off topic. No clutter intended,
Irrelevant? Man that hertz :(
ugh, that was bad.
RE: grille guard questions
Watts up?
I hope you didn't find my choice of words revolting. :P
Ahhh, Ample bad electrical humor.... just what we needed tonight :mrgreen:
-Nick :!:
RE: jeep clubs
XJNick said:
Hi,...............I really didn't mean to clutter this thread with facinating, yet irrelevant information... :mrgreen:
-Nick :!:
There is no such thing as irrelevant information - especially the information you provide here on Jeepz, Nick, that all of us get to suck in for free!!! (and you, too, Twisted). What I would like to learn (the subject of this thread) is everything that I don't know already (or have forgotten.....I'm an old fart, remember?). Unfortunately, don't have enough years left or brain capacity remaining to accomplish that, so I'll settle for learning how to weld and suckin' in all the electrical knowledge I can from my learned Jeepz brethren!!! Oh, almost forgot.........and learnin' the right lines that'll get me and my little "sissy" :lol: stocker TJ up the mountain to where I want to go without invoking the "Winch" command!!
When I was in the service and spliced telecom cables we were always told it was a 55Volt ring voltage so it may vary by company or CO. I did not take time to measure it standing in a damp manhole. Not trying to take sides but offer up another view
I was trying to think up another, but I came up short
Rather shocking don't you think?
I think we have run the circuit on this hi-jack, and although I hate to impede it, because it has been a nice break from debates on current events
I just thought adding a little spark to this thread might be good, I didn't want anyone to blow a fuse :?
