95 jeep yj help
But check for bolts before using anything as a lever... Also, I recommend changing injectors instead of cleaning them. Also, if you are changing them, try to have them balanced (which means they test each individual injector and give you the ones with the closest flow between them).
Isn't there places that rebuilds em? That should be cheaper than buying new ones if they work
couple days go by and i still cant get the damn thing off. here are 2 pics. might not help at all but idk what im doing wrong.
Undo the throttle cable and try again.
