Well mr. Turbogus , I understand your approach to this problem. Your taking the experimental approach to test cause and effect. Can't say I blame you at all . You did the right thing and the problem still occurred ? Might as well try something different to see if change takes effect. Still wondering if jet size change is the answer like those tuner kits have but I'm figuring your after that answer right now. Admittedly , this is working out quite perplexing as it is patience testing but admire your will to get BB back to fighting strength again. Funny thing is , this model carb was designed to overcome some of the problems the original AFB had and now is suffering the. Same ! It's becoming a tuning type session like one would do at a drag strip but this carb is capable of this . Was just hoping a stock setting would have worked as you would want too . Hang on to that fuel pressure regulator , you just never know.
