greg92jeepxj
Official Supporter
I'm still a bit confused as you are . I was thinking the pressure to the needle and seat was too strong causing overflow bypassing the idle circuit and squirting raw fuel above the throttle blades due to excessive pressure . That is what usually happens when too much fuel enters the idle circuit , it overloads and in effect , overflows to the port above the idle mixture screws . That causes the raw fuel to flood the engine. Would have thought , as you'd expect to that the fuel pressure regulator should have cured that . One question ; have you just tee'd in the FPR alone or was the metering rods and jets re-installed ? If not , wondering how the FPR will work,out with the rods and jets back in .
